Hey everyone, I need some advice. I want to put the front axle on top of the springs to lower my truck. How much clearance do I need from the top of the axle to the frame ? Some say 4 inches, but I see lots like this with maybe 2 or 3 inches clearance before it hits.
I've got about 5 1/2 inches clearance now from the bottom of the frame to the top of the spring pack where the axle will go if I flip it. the axle is 2 1/2 tall there, so I will have 3 inches or less travel before bottoming after a flip. Is a c notch ok for the front if done securely ? I see them over the rear axle all the time.
Also, will I need to make shims to set the correct caster of 5-6 degrees ? I plan to weld a plate to the bottom of the axle to help secure it. Any input is very appreciated, I'm trying to save the cost of a dropped axle if I can.
