for the "no expense spared" light wiring setup
8literbeater
Jun 16, 2008
849
Chandler, AZ
I'm looking around for a good fuse panel for my build, and found this. Motogadget m-Unit V.2
I won't be using it, but it sure is nice.
You can do high/low beam headlights without a dimmer switch, without even a light switch, just a button.
You can do tail and brake lights on a single filament bulb, or a single LED.
You can do turn signals with just a button for each side, no flasher.
I don't even know what else you can do with it.
If they'd just make one for a hot rod now... It needs just a few more circuits for wipers, heater, brake/turn signal integration, and a realistic price.
http://store.revivalcycles.com/products/motogadget-m-unit-controller
http://youtu.be/zdIeh2c6O5c
→voltage range of 3V to 20V
