old28
Hoping for a little help and direction on a spindle problem.
After reading a few threads on RRR & the pork site I know that the spindles I have are 1936 early small square units with cast #68 on them and the snout is 5 3/4" long. I understand that as original Ford placed the thrust bearing on the top of the spindle mounting boss ( I have no idea what they were thinking), but that's another story.
The spindles used an original pin with the steering mount on top. I will not need that for the dragster I am building. Spindle pin size is a standard 0.813".
I want to use the flat top 37-41 style pin, but this is were the problem starts.
The top to bottom measurement overall were the pin goes through is only 4.675". The area were the axle sits is 2 1/2" wide. A 37-41 pin is 5.5" long. I am going to install a thin thrust bearing in the normal position (bottom side axle).
What pin should I use? What about the pin lock location? Will I have to cut off a pin and form new lock notch to make it work?
