Ford help.... and offer???
custom cabby
Apr 9, 2008
282
Springfield, Ohio
want to throw something at you guys and see what you think. my f100 has the original 360 in it and is in need of a look through or at the least a complete gasket replacement, and as i mentioned a while ago, the valves need done. i contacted someone a few times and i dont want to pressure him about the valves because he simply does not have enough time. so.... i need someone that would be willing to take the motor (i will yank it) and go through it and just check it out. ofcourse i would love to have it built, but that is way out of my price range. and paying for these services would be cutting it close too (family comes first, as you know). so here is what i'm thinking.... i have an '87 mustang gt that was totalled out by my brother in law. when he wrecked it the odometer has 76,000 original. it is all bone stock (besides the fact he stripped it down and parted everything out and also started on the motor but that was too much of a challenge for him) and is a 5 sp car. the complete drive train is there including rear end. the car is wasted because it was a front/driver side impact and did too much damage to frame... not to mention there is nothing left of the car after he stripped it. it also has the factory wiring harness. i got this thinking that someday i would drop it into the truck but since have changed my mind. i would like to find someone that would be interested in doing some dealing with me on this and maybe come out sweet on both ends. i know its a long shot and dont want to do the ebay thing at this point. so, what do you think. give it some thought and let me know if there is anyone willing to do some dealing.
The 360 FE is a fine engine but not too good on gas milage. They are fairly simple to work on. I suggest lurking in on the FE forums. Depending on what year it is you might want to get a set of D2 prefix heads as those will have hard valve seats. Some fairlane and mustang 390s have a different exhaust manifold bolt pattern so make sure you don't get those by accident.
Anyway, get a set of heads, have them redone and do the change out. Also get an aluminum intake manifold to put back on too.
