Ok, my dad said he had some 53 Truck Brakes off his 40 ford that would most likely work on the A model project. Had to mod the tops of the 37-41 spindles to allow room for the wheel cylinders (new)..Done. New Hoses...Done.... The bearings all look great, cleaned...Done. Hears where it gets interesing. The drums looked good but needed turned. Got to the shop and they're out of round. Had to cut them 60 Thousands to get them smooth. Still look like there going to be out of balance.
Questions... Is the 53 ford truck brake set-up going to work? Are the drums and hub one unit or 2 piece? Reason i ask is it appears they are one unit. Does anyone know a low cost source to get a set of these or what might fit the backing plates and spindles so I can get on with my Cat Killer Project? Thanks all
