kdubya
Love the look of frames with lightening holes along their length. Can they be sleeved with thin wall tubing? Seems like the use of heavy wall wouldn't really make it any lighter. Or, is it just for looks?
the speedo holes really dont make a huge differance on weight, but the look is very cool. we have done it on one of our frames, it just takes lots of time and patience. good luck on your build
DRAGITFAST KUSTOMS
I did some load calculations on my frame with and without the holes, didn’t really care about weight, just the look and strength.
My frame is quite a bit stronger with the holes and tubes welded in than it would be without them using the same wall (1/8”). I also calculated it using 3/16” wall tube.
Adding the holes and welding tubes in them allowed me to use a thinner 1/8” wall, giving both weight and cost savings, but still have very similar strength as a heaver 3/16” wall tube frame.
