Use more wood!
Just kidding...
use a tape measure....
A squared plus B squared equals C squared
sometimes called the 3-4-5 rule
What is square? A right triangle.
A right triangle has an angle of 90 degrees
To show it easy to you we are going to just draw on the floor
go to your corner where you want your 90 degree angle to be. It helps to start with one straight line representing one frame rail or the frame centerline...
snap a chalk line on the floor from your corner to the end of the room.
measure 4ft foreward and make a mark.
Have someone hold your tape measure on your starting point and draw an arc through what should be an imaginary line 90 degrees to the chalk line you snapped.
Have them Hold your tape measure on the 4 foot mark and draw an arc at 5 feet through the arc you drew at 3 feet.
Snap a chalk line from your corner through the intersecting arcs and you are square
If you want to square up a larger area take any number and times it by 3, 4, and 5, to come up with the 3 sides of a larger right triangle.
This method is accurate to the width of your chalk line or pencil marks
