front axle identification
Yankee Transplant
He started out with nothing, he still has most of
Dec 22, 2013
2,278
Mexia Alabama.
Does these numbers mean anything ? I need to replace the king-pins and bushings . but I don't know what year to ask for . they will have to order this , so I need to know what to tell them . any help ? 0227141648-00.jpg
[/ATTACH][/ATTACH][/ATTACH][/ATTACH][/ATTACH]I have not figured out how to make the picture bigger (yet) but i'll get it some time ..
    25.6 KB
    23.6 KB
    28.9 KB
    30.7 KB
    26.4 KB
so I can order pins and bushings for a 50 chevy 1/2 ton and they are supposed to fit ?... If I can get them to order me some and give a description I may be able to look at them and see if they are close before I take it apart .. It looks like if you take the wedge bolt out ,, they will just come strait out .. ( I hope ) they are in bad shape ... Does all axles have those ID. numbers on them ? Oh. thanks a lot for the imfo . Our parts house's here are not to spiffy !!!!! on something like this .. If you cant tell them how many doors , what color it is , and how many rocks are in the floor-board , they cant find it in the computer ...
Well , just like I figured,, Our parts house said .... not in computer ,,,, so we cant get it for you ,,, what did you say it was ?????? (KING-PINS AND BUSHINGS ) let me call you back .... ..... ...... telephone rigs ,,, I say hello .. he says I can get you the king pins but no bushings :confused: What good will kin pins do without the bushings ... He said I don't know they don't offer the bushings [S OK so I found them on-line about everywhere ,, so I'll find some one with pay-pal and order me a set . I have a 5 lug on here so hopefully some one didn't change it out to some thing else . Ive got 49 chevy truck brake shoes on it now so maybe ill get lucky and they will fit .
I just went on the NAPA Auto parts web site and came up with two part numbers for king pin kits for a 1950 Chevy 1/2 ton. Here's the numbers:
NCP 2621296
NCP 2621296010
If you go to a local napa you should be able to have the order those for you without much trouble. I had them do that for my 52 dodge 1/2 ton king pin kit. Hope that helps, then you have no need for PayPal.
-Chris
Yes ,sir eeeee Thank you , very much. I know I really didn't want to fool with pay-pal . Our local napa dealer is about 35 min, away but Id rather get it from a parts house than order it on line . We have an autozone , advance and orileys.. All the old timers that new about cars don't work in these stores here. Ill feel safer once I get these replaced , the drivers side has a lot of movement in it.
One more list that might help ya
Nostalgia Sid's
Kingpin Part Number Chart
Make/Year Moog Part # Napa Part #
FORD
1928-31 .8125 dia
1932-34 .8125 dia
1935-36 .8125 dia
1937-41 Car or ½ ton pickup 8333B .8125 dia 262-1222 .8125 dia
1942-48 Car or ½ ton pickup 8350B .8125 dia 262-1351 .8125 dia
1948-52 F-1 & F2 pickup 8350B .8125 dia 262-1351 .8125 dia
1953-56 F-100 & F-250 8430B .859 dia 262-1388 .859 dia
1957-64 F-100 & F-250 8455B .859dia 262-1411 .859 dia
1961-63 Econoline 8470B .741 dia 262-1014 .741 dia
1964-67 Econoline 8485B .741 dia 262-1465 .741 dia
Chevy
1928-32 car & pickup .734 dia
1933-36 Car .734 dia
1937-39 Car .734 dia
1933-40 ½ ton pickup .734 dia
1941-54 ½ ton pickup stock 8294B .866 dia 262-1296 .866 dia
1941-54 ½ ton pickup 8451B with Oversize OD Bushings Napa don't offer
1955-59 ½ ton pickup 8444B bearing 2-1/8” KP Boss 262-1296 Ball Bearing 2-1/8” KP Boss
1955-59 ½ ton pickup 8468B thrust washer 2-1/2” KP boss 262-1432 thrust washer 2-1/8” or 2- 1/2” boss (has 3/8”spacer)
1941-54 ¾ ton pickup .921 dia 262-1161 .921 dia
1955-59 ¾ ton pickup .921dia 262-1331 ball bearing 2-1/8”KP boss
1955-59 ¾ ton pickup .921 dia 262-1475 Thrust washer 2-1/2”KP boss
1964-70 G-10 1/2 ton Chevy van 8494N .8170 X 5.38
1965-70 G-20 3/4 ton Chevy van 8513N .8752 X 5.54
Dodge
1964-70 ½ ton pickup 8453B or N .8730 dia 262-1378 .8730 dia
1963-68 A-100 8453B or N .8730 dia 262-1378 .8730 dia
1950-56 ½ ton pickup 8453B or N .8730 dia 262-1378 .8730 dia
1960-72 D-100 8453B or N .8730 dia 262-1378 .8730 dia
1957-59 ½ ton pickup 262-1416
Studebaker
1950-56 ½ ton pickup .803 dia 262-1353 .803dia
International
1963-67 ½ ton pickup
1968-74 ½ ton pickup 8390B
I miss the old part house's ,, you could go in them and tell him your putting a chevy engine in a toyota truck and you needed a motor mount that you could make work and he would turn and go down the shelves and look for a min. or two and come back with something that you could make work .... Those were the days !!!!!!
That was nice wasn't it.
I'm lucky in that respect, I still have one here and they will absolutely go out of their way to get what you want.
There's only two of them in the store, Paul who was raised in the industry and his dad Jess who's now 84.
Hedden's Automotive Springfield Mo.
well I got one side out and the parts are supposed to be in at 2 o'clock today so we will see . I new it was going to be a job , but geeesh !!!!!!!!!! I went and took the axle out and pressed it out .. I took them out with a hammer before , but that wasnt happening this time ..
All pins and bushings are back in place , front end back under truck , but have to replace shoes now, the pad fell off in my hand [S Always some thing you really was not expecting to change .. good thick pad , just turned loose . oh well maybe I can figure out why I have a hard pedal but not a lot of stopping power ..
NCP 2621296
NCP 2621296010
-Chris
I give these numbers to another feller in the parts house and he done some calling and got my parts . So thank you very much ..
