bell
Hello all! I'm in the parts gathering process of my '27 Dodge Brothers (4door sedan) build and I'm trying to figure out what to do with the front axle... I could use some input.
The original front axle has NO brakes and the bolt pattern is 5 on 6-1/2"... So I need to figure something out. This will be driven a LOT and I want to get it right the first time.
Option 1- Change spindles/ hubs with something that came with brakes and a common bolt pattern... (are there any other spindles or hubs that would fit it?)
Option 2- Find a axle of similar dimensions from another car/ truck that has brakes/ common bolt pattern...
Option 3- dump some money and buy a blank tube axle like the ones Speedway motors sells... with spindles, hubs, etc...
I plan on running a quarter elliptical front suspension using half of the original front springs and, like I said, I will be driving it a LOT. I want to be able to jump in and drive a couple hundred miles to a show.
I'm thinking option 3 would be best from a safety standpoint... It would be nice to have ALL new steering/ brakes... But that's gonna cost quite a bit more that I was planning... I guess the axles/ brakes is where I should spend the money though.... Just thinking out loud and wondering what you guys though. Thanks, JB
