blacksheep
I am setting up my front end and I notice that my bones are needing to be bent or offset. With my spring mounted it makes the bones run paralell to the frame, and if I pull them toward the frame the spring raises in the center.
Can I cut the bones and make them angle toward the frame more. You can see how they look in my build photos . Thanks
