Front Spring
probchld1953
Active member
Jan 2, 2008
38
Grifton, NC just south of Greenville.
This is supposed to be a spring bought at Tractor Supply, and according to the poster, has worked fine at a fraction of the cost of one from the big Hot Rod Companys.
So,,,,does anyone have experience with something like this, and if it works as stated, what would be the best way to mount it to a straight tube axel that was on parallel leaf springs? Welded on Bat Wings or something else?
Just make sure the pin is centered, and each of the leaves go out the same length each way, and it should work okay. The ride may be a little harsh, but it is hard to say for sure.
