SugarRay8
We had a problem, mainly during right hand turns, with the front wheels “flopping”.
It did it on two right hand turns (both very sharp turns) and once on a straight stretch when we hit a good bump.
So, I’m not sure what I need to change on the front end.
I’ve seen a lot of front panhard bars on cars, is that what I need to add to fix this?
I can get some better pictures if needed.
The front shocks are mounted to the radius rods and the frame, spring is on the radius rods at each end then the center perch on the frame and then we have the drag link tying the steering arms together.
We set the axle at 7 deg. Not sure about toe, caster, camber angles. Also, we followed the Ackerman theory when we set up the pivot points on the steering arms and drag link.
So?? [S
So?? [S
