Dirtyrat
Got Fins?
Just doing some rough planning on the front axle, and suspension.
The plan is the speedway 1/4 elliptical springs.
Now for the question, using the stock ford beam axle from 49, with steering behind the axle, it appears as though it would be easier to make things work with the spring as the top arm of the 4 link, and a single lower link on each side triangulating the front axle. (green circle is where the steering link is 1"Ø)
Obviously this will create a change in caster on suspension travel, reducing caster. Does anyone see this being a problem? Or should I continue on sorting out how to put the spring as the bottom link? Suspension travel is an issue I'm worried about the spring hitting the steering link (obviously I would design it so it will not, but that creates an issue with how low the spring eye needs to be under the front axle).
Thoughts?
Thoughts?
