thom
I have a 400TH trans in my '55 Studebaker truck. I reused the original '55 steering column, wheel, and column shift lever. I like that the truck looks original on the inside. I would like to have a gear indicator though. I know that late model GM products, even some front wheel drives, use a switch that the manual shift shaft extends through for the digital gear indicator and back-up lights. Has anyone rettofitted one to an older trans, like my 400? I would make a small panel for the dash with the letters and numbers engraved on it and put in small LEDs if I can come up with a way to control it.
