Guys, I'm planning the frame for my 38 Chevy truck since I have opted to build a new frame from 2x4 tubing rather than use the original frame. I have already purchased a speedway 4" drop axle front end and my plan is to stack the 2x4 right in front of the firewall for a small kick up in the front then kick the frame up right behind the cab for the rear. I have a GM rear axle out of a cutlass with the factory trailing arms, I already know the lower mounts on the axle will have to be moved inward so they aren't too wide for the frame width. Has anyone used the factory trailing arms for the uppers and just built mounts on their frame. If anyone has, some pics of what they done would be a big help. Thanks in advance.
