Bamamav
I'm in the planning stages for putting power steering on the Lincoln. All the different number boxes is a little confusing, 505, 525, 600, etc. I know the number has something to do with size and strength, with bigger numbers the stronger ones. What I don't know, is how to tell which box is which, and what vehicle to look for a certain number box. Most everybody uses the GM box, so that is what I'm looking for. This will be cross steer, I want the smallest box that will do the job so engine to box clearance is maintained.
Anybody know where to find a application chart for the different GM boxes, preferably with pics so I will know what I'm looking at? I'm thinking 80's on up to early 90's, that seems to be the most common at the Pull a Part I go to. Would like to get the entire assembly, box, lines, pump and brackets, from the same donor if I can, that way I know system will be matched. I'm thinking 80's G bodies, Monte Carlo, Grand Prix, Cutlass, would be what I want to look for? I'm thinking S10 box might be the same, but since none of them had the V8 factory, would still have to find pump and brackets.
Any ideas on where to look?
