Davidhud29
OK my wife has an 02 Explorer. I know it doesn't really fit in the rat rod forum but I need some advice. I have done a lot of internet searching on this. Mostly I just hear people complaining. It has a whine coming from the rear axle. This has been going on for a while. Sounds like I'm running mud tires on the thing. I replaced the tires awhile back and noise continued. Checked the rear oil level and it was low (and leaking). It leaks at the 3rd member axle tubes (independent rear). My options are completely remove axle assembly and replace with Pullapart junkyard axle. Completely rebuild or try and ignore. I have heard people rebuild these multiple times and still have problems. When I first bought this truck I had the rear bearings replaced by Carmax as it was under warranty. It wasn't whining at the time but was making a strange noise. Never was really fixed properly but they said they did all they could, after taking it to them multiple times.
I had a Honda Goldwing with a leaky final drive and the guy I bought it from said his mechanic told him to put grease in it and it would be fine, still leaky but not as bad.
My question is does anyone think putting a high temp bearing grease in the limited slip rear would be ok?
I don't want to cause more problems than I'm "fixing". I know this isn't a permanent solution. I think it may be leaking at the outer seals and bearings now to. Sometimes after a drive you can smell the gear oil burning . In the end I will have to put a "new" axle in. Just looking for a temporary "fix". Until I replace the axle assembly, or buy something else. I still owe 8k on this stupid thing. Trying to convince her to let the thing go and go pay 4k for something cash. Already had to let my work van go (lack of work) and have credit card collectors after me. What's one more?
