billy
Motor mouth ratchet jaw!
WIPE NEW Headlight restore $10
i bought this at walmart this morning because the protective layer on my 13 year old headlights was peeling and yellow
everytime i looked at them i thought
jeeze those things are trashed
this kit comes with a
2000 and 3000 grit sanding pad (very small)
microfiber cloth
nitrile gloves
and a packet with a cloth saturated with some kind of stinky clearcoat
as a professional window washer i am good with a NEW razor blade in a scraper
first i washed the lens then added some soap to it and carefully removed the old layer of protective film (way faster than sanding it off)
then i used some 1600 grit paper i had laying around then the 2000 then the 3000
keeping everything wet with a spray bottle
i spent about an hour total scraping and sanding
then i wiped the lenses with rubbing alcohol soaked paper towels to remove any contaminates
dried them and applied the clear coat pad with only ONE pass
i think they turned out pretty darn good.
verdict
i think it was worth 10 bucks and it for sure worked.
BTW i quickly put the clearcoat pad back in it's bag and right away stuck it in a zip-lock so it wouldnt dry out
if a guy hurried i bet he could treat 10 sets of lenses with it.
microfiber cloth
nitrile gloves
verdict
