Gus
Banned
I have a speedway master cylinder for disc brakes no boost, running 4 wheel disc with no pressure valves.
Why are the bakes holding pressure , so much that it stops abruptly when you let off the gas and sitting on a slope it wont even roll , I know someone else that is experiencing the same problem ??? using the same master cylinder .
It has been torn apart cleaned checked ...
It's not always, it's like it has to build up, my friend has to pull over about every 40-50 miles and release the pressure ??????
Mine was fine when I parked it about 3 months ago but now I fired it up drove it 1 block and it was so bad the back tires were trying to spin because the front brakes were locked down so tight...???? Anyone have a answer ???
