johnnycanuk
- Joined
- Nov 25, 2012
- Messages
- 10
Hi Guys: Am hoping someone can help me figure out what I have. I acquired it a month ago from a friend who had it in his garage for 30+ years. He thought it was from a Canadian Pontiac.Came originally from Saskatchewan.
Block Casting no. 3733813
Block Date code D 11 8
Block serial (stamped on dist. pad. W 9130591
Has two set of Captains Bars.
Has stamped M inside a box in side triangle formed by pass. side motor mount holes.
Head Casting No. 3836848
Head Date Code. C 1 6.
I read from this it is a 1958 261 block with a 1956 235 head with 79.1 cc chambers.
When I opened it I found it had milk can lifters, a cam that has a lift of .045 ish. )Not 100% sure of that as cam still in block and I am a neophyte measuring it). It has .030 pistons and .020 bearings. Rotating assembly appears to be really good with minimal wear. Again novice opinion!!
Engine has flow through oiling (still trying to get head around that system.
It has the fiber cam gear (few cracks)
My thought was to freshen this engine for street and run split manifold and maybe small 4 barrel or 2X2.
Not sure what I have. I am thinking someone got to this engine before me. and changed heads. Probably lifters as well.(My understanding they did not use this type of lifter in 261). I could use some info. and good advice on where to go with this. I understand that this is a good block and head to do up but want to do it right without a major cost. Thanks for your time, John
