help indentfy this axle
52chevyrat
Active member
Aug 8, 2008
35
Chapin, SC
I pulled this axle out of the woods someone turned it into a trailer. There is no damage to it and has wishbones and a tie rod. I dont konow what its from if anyone knows what it could be from it would be a huge help. It looks like early ford 37 - 48 if so there is a huge aftermaket to support using it on my project.
    183.3 KB
    142.7 KB
    130.4 KB
    176.5 KB
What you have there is a '37 or '38 Ford. The axle and spindles are very useable, and if the hubs and drums are salvageable they can be used on '39-'48 hydraulic backing plates. A decent find...
axle
:Dthanks for the help thats just what i was hoping for.:D
do you have any info on what type of spring i need. I want to run spring a spring behide set up. I saw i guy that cut off the spring mounts and fabed up some mounts behide the axle have you ever seen this done.:confused:
wishbones
Also i need some suggestions on how to mount the split bones to the frame. I've seen hiem joints and tie rod ends. Are there prons and cons? If i used hiem joints should build the brackets to run them double shear or not. If I use tie rod ends how do you mount those since they need a 7 degree tapered hole. :confused:
