high temp body filler?
LilD
Jan 19, 2008
467
Tucson AZ
On my 47 theres some rough looking welds on the firewall. Im not this anal but they look bad enough for me to want to smooth them out a bit. IF I get to the point where I want to use some filler, is there a high temp filler or is it not realy an issue?
Didnt think that one through very well did I?[S Yeah you would think if paint holds up filler should too.
there are epoxi fillers they use on boats, can be build up a lot thicker and probably more heat resistant,being epoxi based.
If you really need a filler that will handle higher temps use All-Metal. I use it alot on parts that I powdercoat and never had a problem. (400 degrees, not for headers)........ruggs
