how do i put pictures on rrr ?
robertbandit
Mar 1, 2010
127
mangum okla 73554
where do you put pictures on rrr, isuppose if you put them on you can take them off. is there a book a program? ihave avery good camera i can put pictures on the computer where do i go from there? some of these guys put reallygood pictures on there threads i would like to do it well. i am in apostion to find iron and to buy it. ihave 5 cars now and alot of differentparts i been planning this for years, and rat rods are going to do well i think. when i was younger i worked for quincey"s and lee's both of these places did exhaust systems,and sold speed equipment, and last i worked for granatellia in santa monicaca. 45 years ago, i am in my 70"snow oh by the way after you post a new thread how do you remove it from this machine no use taking up space. robertbandit thanks i know so little and need to learn so much and there is not that much time. plan your work and work your plan thanks:D:D
the way i do it is
go to
photobucket.com
youll need to set up an account but its completely free.
after you set it up its pretty explanatory about how
to load the pictures to that site.
after the pictures are loaded that you want to put on this
site.
then you just use the "html" code - (it gives it to you)
you just copy and paste it in right along with whatever youre typing.
like *here*
You have two ways,
1. click on the mountain looking square in the header when you post and you can insert a url.
2. click on the "manage attachment" below the text box, a browse box will pop up, click and locate pics on your computor then, click upload,submit reply
Also, you can go back an EDIT or DELETE a post. There is a time limit. No need to worry about space, the RRR Moderator has that under control.
