how to deal with abs brakes on frame swap
martin53
Feb 7, 2013
58
New Mexico
I swapped the frame on my 53 dodge truck with a 89 dodge Dakota frame and didn't think about the abs brakes. I have a slant 6 with a 390 tranny I was planning on using the rear axle. What else should I do maybe change out the proportional valves or could I run them disconnected. Is there a way to by pass them
I don't think there would be any issue just running it without the ABS portion, much like pulling the ABS fuse, brakes still work fine, just no ABS.
how to deal with abs on frame swap
Thanks guys well I'm putting a new fuse box. I probably won't mess with anything then thanks guys
