M mashori Active member Joined Dec 1, 2012 Messages 44 Dec 17, 2012 #1 need help with this... here is the HURST shifter I have... what's the best way to wire up a neutral safety switch...
offroadrolls Well-known member RRR Supportor Joined Mar 20, 2012 Messages 1,424 Location In a camper down at the shop Dec 17, 2012 #2 Assuming the switch can handle the load, just interrupt the starters signal wire from the start wire at the ignition. So: start wire at key to Neutral safety switch in and then from the neutral safety out to the signal post on the starter solenoid.
offroadrolls Well-known member RRR Supportor Joined Mar 20, 2012 Messages 1,424 Location In a camper down at the shop Dec 17, 2012 #3 Also it looks like you have 2 switches there The other may be for the reverse lights?
G geonbugman Banned Joined Nov 13, 2012 Messages 21 Location Columbus Dec 21, 2012 #4 http://www.freeownersmanualpdf.net/...shift-lever-kit-installation-instructions.pdf Instructions!!!!!!!! I use them for hand wipes!
