hydrolic clutch
the reverend muddy grimes
Brother Binder
Sep 9, 2009
1,239
Springdale Ar
never liked em, but sometimes you have no choice. Ok, what ive got is a chevy 3 speed (saginaw) with a manual clutch set up. The IHC had a manual clutch, but the arm is reversed so you cant match them up. What I am thinking is getting an old style master cylinder (like off a willys jeep) for brakes. hooking the clutch pedal into it, then mounting a slave cylinder by the clutch arm and seeing what it takes from there. suggestions? pics? reasons why this is the most crackheaded idea ive ever had?
Curious as to why you don't just snag what you need from a hydro clutch system out of a 80-90's truck instead of messing with a brake system? Aren't there some with external slaves?
You could try building a "Z" rod that would reverse the manual rod. Or the early 90's chevy trucks had a remote slave that looks like could be made to work and the masters used a bolt through where the later ones used a twistlock in a square hole.
    3.7 KB
s10's- astro vans
i am a straight shift man i use s10 80's - early 90's , 95 and later are internal slaves, u can use them on any model with a clutch fork, and i also use astro van 80's they havd a good size res on them and are low profile
