rollingthunder
- Joined
- Nov 26, 2011
- Messages
- 85
So I took my brand new 9 inch housing to a local body shop to have my coil over mounts weld strong... I asked for him to put the pinoin at 2 degres up...so when the axle is perfectly sitting level the axle braket should go 3 degrees back so when the are put straight up and don't forr the coil overs then the pinoin kick up 3 degrees...easy right??? Well I just got the axle back..and the pinion when the brakets are 0 degrees vertical is 9 degrees!!!! I'm so ****ed right now it unbelivable.. I can bring the pinion angle down to about 4 degrees but then the coild over brakets do not sit flush with the coil over bolt it bends it slightly....what the hell can I do...make a shim..I'm steaming!!!!!!!!!
