Ok I've been poking around here for awhile now, and doing quite a bit of reading, and talking to some of the local rat rodders trying to get some ideas. Now I have a few questions for you guys, regarding my future frame.
From what I have gathered after a few hours of reading frame building threads and the "how to build an early hot rod frame" thread on the HAMB either 2x3 or 2x4 square tubing thats at least 3/16" thick is the preferred material for frames. And 1/4" is only necessary in the higher horsepower applications. I also know you need to have your rims, tires, motor, tranny, front and rear end, for mock up.
Now onto my project. The body is a 31 Ford model A, the motor is a MOPAR 440, with a 727 torque flight, and this weekend I'm picking up a Ford 9" for the rear. I still haven't figured out a front end yet but I'm leaning towards a 3 inch drop axle. As for rims and tires I was planning on running artillery rims both front and rear, with 31" tall tires on the back and something a little smaller on the front. For stance I want the body channeled 2 inches in the rear and 4 in the front. I'm not a big fan of suicide front ends so I will run a model A front cross member to keep as close to the factory look as possible. For wheel base I would like to be around 106" . Suspension wise I had planned on a 4 bar with air bags in the rear, as for the front, I haven't gotten that far suggestions are welcome.
On to the frame, awhile back I picked up a set of CAD plans for a model A frame. There is a 15" Z in the rear and 4" in the front. The material call out is for 2"X4"X1/8" wall, its setup for a SBC 350 with TH350 and 4 bar in the rear. Now I know its my car and I can build it the way I want, and the frame plans are more of a reference than my exact plan of attack.
Now for some questions.
As far as square tubing goes will 2"x4"x 3/16" be heavy enough? That 440 is not light weight motor, and it will be pushing somewhere in the neighborhood of over 400 ponies.
When it comes to actually welding the frame together besides beveling the edges to be welded keeping it square and level are there any other trips or tricks I should know? Keep in mind I dont have any frame jigs.
After the frame is all tack welded, how are you guys finish welding the frame? In the back of my mind I keep thinking stitch welding........
Lastly what do you guys suggest as far as a front end? Is an I-beam better than a tube or is it all personal preference?
Sorry for the long winded post, but I figured it would be easier for you guys if you knew what my plans were for the car.
