First you need to decide if you want the front end to stick out as far as it seems to!! It seems kind of far out there in the pics!!
If it's too far out, you'll need to remount the rear of the hairpins!
If the front is where you want, the next step would be to determine if you can get enough caster in the front with the adjustment you have !!!
Question, do you undersatnd what caster is???
If you do you'll need to be able to get at most around 10 degrees, minimum of around 4 degrees!! If you can't get that much caster wit it sitting at ride height, you'll have to relocate the rear mounting point of the hairpins!!
(lower, or higher) as to what is needed!!
As far as the frame goes if you're happy with the way the kick up looks now, it can be extended and be made to work! Personally I wouldn't just butt weld extentions onto the ends, I would cut the angle weld and reweld it right there, it would be a little cleaner!! Whatever you do, make sure a person who knows what their doing welds these critical areas!!
More pics that show the entire layout would help, these are just a few ideas.
One other thing to remember, take the WHOLE thing into consideration BEFORE you weld anything!! It's always easier to do it once!!
