junker39
I picked up a front axle out of a '90 Comanche and I'm just in the planning stages right now, on the best way to get it under the Ghia. I really need to get the steering behind the axle so all the crud isn't hanging out front. And, so I can still use the rack and pinion I've already been using. Is it possible to swap the spindles,(or whatever they're called nowadays) from one side to the other, without totally screwing up the geometry of the steering??[S It'll be mounted using leaf springs so I've got some homework to do on where to roll the axle as far as the caster is concerned. It's more the camber that concerns me. Just wondering if anyone has ever tried swapping sides and how'd it work. Thanks.
