king pins
make sure you have the pin lined up, they will be tight, you should just have enough sticking thru to get the lock washer and nut on, I use a hammer and give them a light tap, then tighten and tap, tighten and tap. They fit very snug, and you have to tap them out with a hammer, do not over tighten them they will break off at the base of the threads and then you got a problem getting them out, after you drive it a few miles just check the nut and make sure it stayed tight, I check mine every couple of months.
