Model A axel setup
Anglianut
Active member
Aug 24, 2010
26
Dinuba, CA
Here is a quick front axel question. On a model A axel, where the bones meet the axel boss, are there shims or washers that go there, or are the bones close enough fit to the axel that nothing is needed? Im trying to put together my jig saw puzzle for the first time without any instructions:eek:
front end
The only time you need spacers is when you are using later bones with an early axle, you will have a 1/4" gap, and they make spacers to fix that problem, if it fits tight you are ok, just bolt it up and your good.
