Model A Frame? Help identifying!
onetondodge
Apr 27, 2010
162
Houston,TX
Hello all,
I am looking for help identifying this frame, I think it is a model A frame. I have thoughts of boxing it and using it for a track t. Thank you in advance.
Paul
Yep, Model T. Normally not used for hot rod building because of it being very weak and flexible, but for a little track car with a 4 banger it would be ok. You would have to box it, add some crossmembers, and lose that front axle because of the odd spindle set ups. But for a light little car it could be used.
Thanks guys, I know less and less when it comes to these old frames.
Don, That is along the lines of what I was thinking, A little four banger. There is a track t that is always at the local car show and I fell in love with it. Do you think that rear end could make it, or find an upgrade of somekind?
I would do this build instead of the second dodge, I would sell it and build this.
Thank you
Paul
