DirtRatsSpeedShop
ok what is it called when the front leaf spring is mounted in the original position on the fram ya know under it the is mounted to the wishbones by some welded on tabs?
i have tried some diff setups like a perch and stuff but i like the look of this way the best. i have tried it but my spring goes too far donw shound i remove some of the leafs and have the weight of the motor pull the spring back up?
here is a pic of the f bomb by the slc throttlers its not a good pick but its the ride height i am going for and his spring is almost flat
