more confusing
robertbandit
Mar 1, 2010
127
mangum okla 73554
i was told chev did not do 5 0n 5 on chev p.u. till1971 was told early chev straight ond rear end , they got a chev car donor front hubs and drums and swapped out the rear axles to. early to late what year would front and rear axle possibleybe early to late what year would the donor car be to make that kind of interchange on parts? any books on this has anybody else done this i need to know what years i am dealing with to get the right parts. the word clustersomething comes to mind. this early chev straight axle and rear end and some one swapped 5 bolt smallchev hubs and drums and rear axle is this possible would you have to swapp spindles also and then what would do on rearend i did :confused:this was or is possible well help thanks robertbandit
It depends on what year front axle you're using. I do know that 49 - 54 Chevy car front hubs (5 on 4 1/2") fit right on to 55 -59 Chev / GMC pickup front axles. As for rear axle, there are lots of choices depending on the bolt pattern and width you want for your application.
What vehicle are you talking about ? [S More input needed...:confused:
confused
i found achev straight axle and rear axle at the junk yard assuming they 49 to 55 asuming correct axle in rear end and front hub i did not know chev did not 5 bolt hub till 71 found out front axle and rear takes a small chev wheel passenger car? i am trying to figure what years the front axle might be, also how they would go from 6 hole wheel small chev, what you have to do to do that and what year the donor car would have to be i do not know what year the front axle and the rearare. i do not what year the donor would be or was. what years did chev build a straight axle in pikup? what year did chev make small bolt pattern front hub and rear axles that would interchange? are there any books on this? i have to go with parts that i can find out about and replace if need be. thank you robertbandit:confused:
