blacksheep
Ok, so I'm setting up my rear end on the bucket truck right?. It is driving me nuts. I will explain what I have so far. Last week I tacked the rear spring pivots onto the rear axle,after setting the rear pinion at 3* up. I connected my radius rods to the frame and dropped her on the springs. I noticed that the frame was setting leaning to one side, and that my shackles allowed the spring to hit the pivots when we stand on the frame. Ok, I said well maybe I don't have the spring pivots out far enough on the axle. I cut the spring pivots loose and turned the pivots at about 30* out, mainly because I don't have enough room before they hit the radius rods. So, I tacked that together and I noticed that the frame is leaning once again,but that the shackles are slightly pointing at the ground.So, before I went in the house I took the radius rods loose from the frame, and I noticed that one rod seems to be out of adjustment higher than the other one. I plan on adjusting both rods to where they both allow the bolt to just slip into the frame instead of one being hard to get in. Could this be the cause for the slight lean?. I took a reading on the frame once I let the radius rods loose last night and the frame popped back to level.I am about to just throw the buggy spring in the weeds and use coil overs. I am learning alot here on cars. With bikes , you just have two points to get right and not 4 . hahaha.Sorry for the book here.
