Mystery transfer case
zzrodder
May 14, 2010
3,895
The Sunny Okanagan B.C. Canada
I inherited this tranny and transfer case with the Packard stuff, came with bellhousing, flywheel etc to fit SB Ford, I appears to be a Ford toploader 4spd with a Hurst shifter. The transfer case says Spicer on the back, looks like it may have had an OD unit on it at one time. Is it from a Bronco maybe?? I know diddly about 4x4 stuff, wondering if it is worthy or just fragile old stuff. Also could a mainshaft and tailhousing from a car type toploader be put in it to convert it for car use?? Also came with a 3spd toploader, guessing it's from a Mustang or Falcon? Any help would be appreciated :)
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
    157.5 KB
    158.8 KB
    173.1 KB
    167.5 KB
    160.8 KB
You are right about the Jeep connection. Some Googling led me to find that it is likely a Spicer 18, may have had an OD on the back or a PTO - or just a tin cover. Found pics of it with a Ford toploader 4 speed but no info on what it may have come in. There looks to be an adaptor plate between the Ford case and the Spicer unit. As far as I can tell, the old Broncos didn't come with this transfer case, so where does this setup come from??
attachment.php
attachment.php
    21.6 KB
    197.9 KB
Jeep used the twin stick transfer case, but I think their transmission had internal linkage, at least the couple I had did.
This unit was installed in an old IHC Scout with a 302 Ford by someone long ago...
It's certainly a Jeep transfer case, with the inline outputs, what mystifies me is the Ford toploader 4 spd on it. Now that I think about it, I knew a guy in the 70's that put a 302 Ford in a military flat fender Jeep, and used a kit to adapt to the Spicer transfer case, he also added the overdrive unit - I'll bet this is one of those kits - by the grunge on it, it's been together for a long time. I actually had a ride in it, even with a stock 302 it would do wheelies and with the military tires it was unstoppable off road, a fun toy.
I remember JC Whitney sold those adapter kits, you could get either a Ford or Chevy IIRC. You're probably on the right track with it being aftermarket.
