Narrowing the rear frame rails on 63' Falcon Ranchero
CoolVanilla
Oct 19, 2014
23
TX
Has anyone attempted this little project? I've seen Falcons at the drags running big slicks and they have them tucked all under the car - no cutting out the wheel well.
Don't think that's possible! Maybe not the outer but no way without cutting the inner! [S
Toad
Sure, done all the time. Best way to do it is to "back half" the frame, where you cut off everything forward of the rear end, run a rectangular tube across the cut off sections, and then make up or buy two new frame rails that you weld inboard further than the old ones.
A lot of work, and not real cheap, but it is the right way to get big tires under the back without cutting into the body. Here is one such kit:
My Son is doing a mini tub on his Fox Mustang, and he moved the frame rails in enough to clear big tires.
