UncleDonnie
I traded a muscle car for this, it drives good but rides like a lumber truck. I started looking into the suspension and bags will work with the ladder bars in the back in place of the coils.
The front is another story! There is hardly any movement and I weigh 280, it should move. It has what look to be Harley coil overs and a stock 30 something leaf in the front.
There is a rack & pinion bolted to the beam axle and the first thing I've done is put a slip joint in the shaft between the column and the rack.
The radius rods have been welded to the axle. It has a Panhard bar that looks pretty good. At the end of the radius rods the anchor is a tie rod end and this is what is taking all of the trust load.
I'm assuming the Harley shocks and welding the radius rods was to stop a death wobble. Should I be freaking out about all of this or is some OK? I'm gonna start with pulling the coil overs off the see if it helps the ride but doesn't cause a death wobble.
