neverwintercycles
- Joined
- Sep 13, 2008
- Messages
- 12
hey all
so here's where i am at with the 53 dodge
frame is back from sandblasting, picked up new disc rotors and pads and bearings for the camaro rear end, and ordered the disc conversion kit from rustyhope.com. once he send me the needed parts lis ti'll get that stuff. that should cover the braking stuff - except the m/c and pedal assembly but i'll wait till i get further along before i get those as i am not sure if i'll go floor mount or firewall mount.
so i'd like to focus on getting all the suspension done. ideally i'd like to run 16 inch rims on the front with 6-7 inch wide vintage style wheels. 5 x 4.5 bolt pattern is what i need
for rear prob 16 inch wheels with a little wider vintage style tire. i know coker has the tires. what i need to find out is where to get semi-inexpensive (used is fine) wheels that will fit the calipers on the disc setup. is a local NTB going to carry stuff like this? i am hearing of back-spacing, etc etc? i am a newb so this is all new to me
thanks for any help
thanks for any help
