Coffee Freak
I am hoping to use this: http://shop.eztbucket.com/GMC-Front-Axle-Adapter-Kit-5016.htm
To mate up a Suzuki Samurai front axle to my frame. I'm hoping to use the batwings that come in this kit and use u-bolts through the holes in the flat mount to have a truly bolt-on front axle.
Can someone that has a half ton GMC axle get some measurements for me? First off, I'd like the 4 bolts that make a square where the factory springs bolt to. From what I've seen, that generation used a 2" wide spring, so the spring width should be the same as a Samurai. I need to know how much space there is between the bolt holes front to back to see if the axle tube will fit between them. I'd also like to know how wide the track width is between the two inner most bolts are right side to left side. If this doesn't make sense, I can explain further. From what I can tell, the kit will give me some leeway, but I don't want to skew the angles too much.
I know there are cheaper ways to accomplish this, but I'm not comfortable welding 1/4" brackets onto thin sheetmetal axles tubes.
