J
justsomeguy
Guest
Some buddies and I were discussing some of the scary brackets we've seen on rods. You know the ones I'm talking about. Cobbled together, bird poop welds, undersized, and dangerous. The guy in his garage building his first car might mean well, but could be doing something very dangerous without even knowing it. Beyond that, how many frames and suspension components have you seen built with under powered welders?
We came to the conclusion that it would be nice if there was some type of bolt on bracket that could make sure people are using safe hardware, but be cheap enough that the shoestring buget builder could swing it.
This is a panhard mount that would bolt on over a 2x4 or 2x3 frame rail. The slot is deep enough that the bracket would actually be transferring the load to the frame rail. The bolts would just be used as clamping force and to keep it in place on the rail.
I know this isn't for everyone as there are plenty of guys out there with great fab skills, but these could also be used for mockups before you weld on your permanent brackets. Supreme adjustability before you make it final.
What are your thoughts on this? I would really appreciate some feedback. If anyone wants to see some more drawings of different mounts, just let me know. Heck, if somebody wants to try one out I need to make a prototype anyway.
