parallel,suicide or quarter elliptic
chopped 49
Jan 6, 2009
5
Whats up guys...I am putting a straight axle back in my 49 f100. The front frame section will be Z'ed 6" what do you think of just going back to the parallel leaf spring set up. I will be driving it a lot to work in the summer so I think it will handle better. I was going to go suicide or quarter elliptic.I have some good set up tips for those style for my perch style axle. I just don't know how it will handle on the freeway? What do you guys think. I know the parallel spring set up does not look the best, but should I give up handling for looks. This is my first build. :confused:
First off is it going to be fenderless? I'm assuming so anyway. I'd go with the dropped axle, four bar or radius rods. For steering maybe go with a cross steer setup, helps avoid bump steer. The other guys on here will give you good advice also, alot of experiance on this board. Good luck with your build.:)
