Anyone have any pics? Wondering about placement, best one to get, vacuum assited or not...
Thanks
Thanks
Coup, I am really glad I finally put a vacuum power brake system in my 55 Merc pickup. It has discs on the front and drums on the back. You don't have to push those pads very far onto the discs, but you have to push them hard, so the power brakes are a way nicer. My unit is from a hotrod shop and is a dual diaphragm, small diameter one but I don't know the brand name. It is under the floor.
On my '36 Ford truck I used a Ranger frame and put the vacuum booster from the donor Ranger under the floor, [a tight fit], but it works nicely.
if you run power steering , a hydraulic booster may be the way to solve space issues.
I used an under the floor master w/booster in my '41 Ford PU. Here it is before plumbing! At the top you can see the brake pedal arm! I boxed the frame & used a tubular x-member!
