Power cowl steering progress pics
Willowbilly3
A *real* tin magnet
Dec 10, 2007
7,847
Black Hills South Dakota
I've been putzing with this for a few weeks and today I got after it. I had to pull the tub off to get'er done. I will mount the steering wheel out through the dash and it will be mostly perpendicular, like an old Corvette. I will also run the lines after I get the engine and firewall installed and the pump mounted.
    65.6 KB
    62.2 KB
    65.3 KB
    68.5 KB
    77.8 KB
I like the undercowl subframe you built, very strong. What are your plans to extend the sector shaft out the side?
In the center photo you can see how I extended the shaft. That is long enough but I can also slide it some on the keyway if I need a little more.
I took a pitman arm and farm implement pto yoke to the machine shop and had the yoke made that goes on the pitman shaft. This is getting expensive, probably have $100 into it already.
The one question nobody asks is about the Saginaw steering box. It has to be reverse from what most cars have.
    56.9 KB
