zzrodder
I'm having a real problem getting the brakes to bleed. I bench bled the master and also got a Mighty Vac tool to pull the fluid through to each corner but I can't get it to push any fluid to the front or rear at all. It's driving me nuts !!
I've installed the usual Wilwood 2lb. front and 10lb. rear residual valves (the rear one is not visible, hidden behind the exhaust heat shield). The only thing I can think of is that the residual valves are preventing the master from pushing enough fluid through to build pressure to bleed out the air??[S
I'm considering making a plate to mount to the top of the master with an air fitting on it so I can use the compressor to pressurize it and force bleed it...
Good idea or bad ??
Good idea or bad ??
