Proportioning Valve??
RAT IHC
Jan 2, 2011
525
St. Petersburg, FL.
So the brake booster/master cyl kit that I bought came with it's own proportioning valve. I didn't notice until today, but there are two out ports for the front brakes (disc/drum setup). Anyone know if I have to "use" both ports or can I just use the one for both front disc with a t-splitter?
Thanks for any input...I've never had to run two lines for front disc before so I'm a little stumped on this one.
-Troy
That's so you can run your lines from either side, plug the one you don't use! It should have two for the back too.
Toad
i have wondering about the same thing well almost, do u have to run a splitter like on a stock truck or can u just run a splitter off the master cylinder ?? im stumped as well.[S
Toad
One was on the top and one was on the bottom....there was only one port for the rear. I saw a similar one Summit's site and attached the PDF that was on their site.
I suppose you can do it that way...maybe someone else has some input.
-Troy
    33.9 KB
My MC had 3 ports(two on side one on top). The donor car I got it off of had a line running to each front wheel and one to the back. The two were tied together so for convience of not having to run three lines I capped the top one and ran one line and put a "T" down on the cross member.
    44.3 KB
Thanks for the input guys. I talked to Speedway Motors street rod tech and when I asked the question he didn't hesitate to say that I can just use one port and a splitter for the front brakes and plug the other hole on the proportioning valve.
Now all I need to do is find a plug! Anyone now where I can get one? It's a 3/8 - 24 IFF (inverted flare/female)
Thanks!
-Troy
