Questions about flat paint
GTOKID
New member
Sep 13, 2008
3
Hey all,
Go lots of questions. I would like some help/tips on spraying flat black paint. The last time I sprayed a car was several years ago using single stage. Do you wet sand? Clearcoat? Also, I was thinking about spraying the chrome bumpers too. I really don't want to destroy the chrome. Can I hit them with a few coats of primer and spray the flat over? Thanks guys.
When I painted my truck a while back, I used a single stage top coat from a local supply house. (with flattner added)
Wetsanding, is up to you
clear coat, is up to you also.....I elected not to clearcoat(Mainly because I'm a cheap-skate):D:D
If I had chrome bumpers, I would leave them chrome and clean them up as best I could.(My opinion only)
Hope that helped.
Just sprayed mine a while back. Single stage urethane with flattener added to get your desired effect. Just shoot a little on a test panel until you get it right.
Hey all,
the easiest flat i've sprayed came from e-bay called kustom shop hotrod flatz a "kit" included the reducer and hardener/activator and was around $150 worked real well and it was a single stage urethane no way to wet sand and buff flat paint as it will defeat the flat look you're going for- but there is also flat clearcoats if you want to go that way......
i'd not recommend spraying the chrome, but if you think you must, then a real good epoxy primer will help hold the paint to the chrome...
hope that helps ;)
