Radius rod modification?
Mick41Willys
Jun 12, 2010
60
Peachtree City, Ga.
My 4" drop axle came with the axle brackets already welded. The rod ends are about an inch to narrow to clear the frame. would it be ok to cut a saw blade width 3/4 of the way thru the rod, bend it till the cut closes and weld it back. Is this a good idea or bad. Need advice. Only needs to bend 3 to 5 deg.
Mick
