projectF1rat
Banned
- Joined
- Aug 2, 2009
- Messages
- 24
So i have my radius rods and everything. I just want to make sure that I am setting up everything right. I have the angle finder at 7 degrees. i ground down the top of the king pin so it was flat. i put the frame on jack stands and pulled the wheels off. Question if one side is at 7 degrees do i still need to check the other side or should it be good. also how far out should the mounting be from the frame as far as a spacer. I have attached photos for a better idea of what im trying to do. any info would be great. thanks
